440 EX Question
Old Dec 25, 2004 | 11:13 PM
loudnfast's Avatar
Default 440 EX Question
Ok im about to be ready to put the engine back together. But the top end gasket kit that i got did not come with the o-ring at the base of the cylinder. I would like to know if the o-ring is just somethig that the factory put there to help seal the sleeve to the cylinder if there was a slight defect. Or if i need to find an o-ring for the base of a 440 sleeve. Any info would help. Thanks Andrew.
P.S. Here are the components i will be running-
Wiseco 89 mm, 11:1 Piston
DynoJet Stage 2 Jet kit
HotCams Stage 2 Cam
FMF Power Core 4 Slip On
Any Suggestions or Comments would be Helpfull
Old Dec 26, 2004 | 10:39 AM
tprender's Avatar
I don't remember any o-ring on the base of the cylinder. all that I can remember was just the base gasket on the case and and the cyclinder, but I could be wrong. Hope that you put in the larger studs with this. If you blow a head gasket later, you will need to have them put in. The stock head is soft medal and the stock studs with the larger compression will put the studs. Most people think that the head gasket is bad. The higher the compression the more likely that it will happen. Best of luck and you will like the 440 with the extra power. I had to run a 16t sproket because of the extra power.
Old Dec 26, 2004 | 10:51 AM
Ozark38's Avatar
I don't know anything about the O-ring either way. I just wanted to say I'd go with a full exhaust on that set up (FMF Powerbomb).
Old Dec 26, 2004 | 08:22 PM
loudnfast's Avatar
Thanks for the input guys. As for the exhaust i wanted to do a full exhaust but the funds are limited right now. i actually like the LTE Duals though.
Thanks Andrew.
Old Dec 29, 2004 | 11:51 AM
cals400ex's Avatar
some run the 0-ring on aftermarket sleeves, others don't. mickey dunlap told me not too so i didn't put it in.
Old Dec 29, 2004 | 02:17 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I didn't either.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
