odyssey fl250 suspensions
Old Sep 11, 2000 | 02:15 PM
cyberpunk's Avatar
I purchased a used odyssey one year ago. It is lots of fun however it gets pretty bumpy on rough terrain, so I was wondering if there is any way of installing a rear suspension? perhaps an aftermarket kit ?
Old Sep 13, 2000 | 01:30 PM
LiveWire's Avatar
There are kits, I don't know from where off-hand. The ones I have seen are pretty simple in construction. The axles are cut near the frame and a U-Joint connects the the outer pieces back on. A pillow block (flange that holds a bearing) is mounted to an arm connected forward on the frame with a rod end. The shock mounts to the arm near the pillow block. You can get the U-Joint assemblies and the pillow blocks from a store that sells farm impliment parts.
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
