Twin Cylinder carb retro???
Old Dec 27, 2004 | 11:05 PM
GoingVirtical's Avatar
Default Twin Cylinder carb retro???
I knew a mechanic that was experimenting with swaping out carbs from a sp500 to a 600/700. As you know, the 500 has a larger carb on it. According to this guy, there is a world of hp waititng to be unleashed. I lost contact after moving. Any of you guys tried it?
Old Dec 28, 2004 | 01:42 AM
SPORTSMAN70003's Avatar
I put one on mine the other day and it really came to life. I need to go to the dealer tomorrow and pick up some bigger jets because it is running to lean. I took it for a test run to see how the jetting was and still can't get over how much power it has[img]i/expressions/face-icon-small-happy.gif[/img] can't wait to get it tuned in.
Old Dec 28, 2004 | 07:20 PM
Besides the re-jetting. Was it a bolt on prosess?? or did you have to modify the carb off the 500
Also was there a big enough difference in power that would suggest doing it?
Old Dec 28, 2004 | 08:10 PM
All you do to bolt it on is redrill the mounting bracket. The choke cable is different where it screws into the carb you need to buy the piece that screws in the carb for the 500HO. The throttle cable where it screws into the crab is to long and needs a spacer so it don't screw all the way in. Power is unreal I still haven't got it tuned in but it's really worth doing. Oh yea make sure it's a 500HO carb.
Old Dec 29, 2004 | 07:51 PM
Thanks for the info. I'll check it out
Old Dec 29, 2004 | 11:27 PM
tpalm5's Avatar
That sounds extremely interesting....let us know about any further developments. Maybe someone can do a dyno run to see exact figures!!
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Jul 7, 2015 11:00 PM
