WHY WONT THE MOJAVE START
Old Dec 30, 2004 | 04:23 PM
MOJAVEalltheway's Avatar
Default WHY WONT THE MOJAVE START
its cold out round - 10c and my mojave wont start
i tryid to jump start it and kicked it outer alot but it wont start
someone help me
Old Dec 30, 2004 | 07:25 PM
tuffEnuf's Avatar
Charge battery, Ensure cable posts are clean & Choke full on, clean plugs, turn Fuel petcock on, ensure you got gas in tank, Put in neutral, Ensure Kill switch is not on, Couple shots of starter fluid in airbox, & close lid, turn on Key, start or or pull start it. Let it warm up awhile before bringing to idle[img]i/expressions/face-icon-small-cool.gif[/img] If it fails to start with starter after 10-30 sec, try pull start, if it starts with pull start after a few pulls have your battery tested/replaced.
If you still can start it. Put a heater on it/place in heated garage and re-try
Tuff
Old Dec 30, 2004 | 07:29 PM
its a mojave, kick start only no batery
Old Dec 30, 2004 | 08:35 PM
kawakasi's Avatar
Is it always hard starting, or just when its cold?
Maybe check the spark plug???
Maybe check the valve clearance???
Kasi
Old Dec 30, 2004 | 08:39 PM
how do you check valve clearence?
do you have to take off the head?
it would be great if you copuld send a diagram or instructions?
im only 14 and im new with this stuff
Old Dec 30, 2004 | 08:42 PM
hey kawasaki, if i put an 11 tooth sprocket on weith my 24 ich bear claws that would bring back the tourque that it lost with the bigger tires rite?
Old Dec 30, 2004 | 10:37 PM
kawakasi's Avatar
MO
you need a book.....a clymer manual is a good choice...it will tell you eveything you need
I put the 11 tooth front sprocket on to slow my sons unit down....
Yes you will gain some torque
Kasi
Old Dec 30, 2004 | 10:51 PM
fartman's Avatar
could be a couple problems, check your plug, check your gas, make sure your getting spark and keep trying.
Old Dec 30, 2004 | 10:53 PM
summitlt's Avatar
If you got fuel, spark and air it should run. If i was runnign before, I cant see vavles being out of adjustment, doesnt work that way...
it could be from the cold, try a little starting fluid or jsut regular gas down the carb.
Old Dec 30, 2004 | 11:06 PM
my dad said not to use fluid but ill try the gas
