Hey electrcians....
Old Jan 2, 2005 | 05:42 PM
okiedude's Avatar
Default Hey electrcians....
My winch on my 500 is not working all the time. You can use the "in"-"out" button and you can hear the contactor clicking but the actual winch only works about 1/3 the time. I have cleaned all the terminals and made sure the wires are tight, but besides opening the contactor, I dont know what else to do. Surely if the contactor is "clicking", it is working right? ANy suggestions?
Old Jan 2, 2005 | 06:29 PM
Bionic's Avatar
Loose Ground=intermittent operation. Check ground at frame near sol. check worn, frayed wire. Low voltage on battery? I am a Master electrican but that does'nt mean sh!# sometimes. If you have a multimeter and a shop manual you can squash some of the guesswork. Radio shack and Home Cheapo have cheap meters.[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jan 2, 2005 | 07:34 PM
elkbow's Avatar
I can almost guarantee you that it is your positive '+' battery connection. Since you have to put the power wire on for the winch along with the regular battery wire, its really sensitive to having a perfect connection. Pull both wires off, Make sure that each one is perfectly flat and no corrosion, then retorque down. Make sure they are tight....
dave
Old Jan 2, 2005 | 08:10 PM
okiedude's Avatar
Thanks guys.... I didnt pull either neg or pos off the battery, but just made sure terminal screws were tight. So you both agree it is not the sol. right?
Old Jan 2, 2005 | 08:33 PM
elkbow's Avatar
I doubt its the solenoid. The reason the solenoid is clicking is because of improper voltage/current. Its a connection somewhere...either at the solenoid or the positive on the battery...or possibly ground...
Old Jan 3, 2005 | 01:53 AM
hondabuster's Avatar
Was the motor running? Those winches are real power hogs, and if the engine isnt running, the battery will run down real fast.
