Hey electrcians....
My winch on my 500 is not working all the time. You can use the "in"-"out" button and you can hear the contactor clicking but the actual winch only works about 1/3 the time. I have cleaned all the terminals and made sure the wires are tight, but besides opening the contactor, I dont know what else to do. Surely if the contactor is "clicking", it is working right? ANy suggestions?
Loose Ground=intermittent operation. Check ground at frame near sol. check worn, frayed wire. Low voltage on battery? I am a Master electrican but that does'nt mean sh!# sometimes. If you have a multimeter and a shop manual you can squash some of the guesswork. Radio shack and Home Cheapo have cheap meters.[img]i/expressions/face-icon-small-frown.gif[/img]
I can almost guarantee you that it is your positive '+' battery connection. Since you have to put the power wire on for the winch along with the regular battery wire, its really sensitive to having a perfect connection. Pull both wires off, Make sure that each one is perfectly flat and no corrosion, then retorque down. Make sure they are tight....
dave
dave
I doubt its the solenoid. The reason the solenoid is clicking is because of improper voltage/current. Its a connection somewhere...either at the solenoid or the positive on the battery...or possibly ground...
