how to run richer.... (400ex)
Old Sep 12, 2000 | 09:51 PM
c400ex1234's Avatar
I currently have a white bros s-bend pipe. I am using the dynojet 170 (largest one in the kit) with 8 disk's. If i use anymore disk's it runs lean. Right now my plug is a greyish color. But when i run more than 8 disks it is reall'y white.
I want to run more disks, but i don't have a dynojet main that is larger than 170. What could i do?
I have a uni-filter with a large hole in the airbox cover.
I want to be able to run richer.
thx
Old Sep 12, 2000 | 10:07 PM
400exalltheway's Avatar
cover up the hole in your airbox
Old Sep 12, 2000 | 10:31 PM
hot_shoe_cv's Avatar
That's one of the problems (among others) with that kit..their inhouse jet numbers don't co-inside with other brand's sizes.If it were my decision I'd lose the jet you now have in it & buy two or even three sizes fatter from stock in a keihin jet and do your test/plug read again. I'd think with your current no. of discs two would put you close to the right mix and adding more discs will make use of the third jet. If your plug is white, you'd be wise not to ride again until you have corrected the dangerously lean condition.
Old Sep 13, 2000 | 12:15 AM
Motorhead's Avatar
I've got a stock 400ex with the WB E-series, and the 155 main I got from the honda dealer is just right. My air box lid is still intact, but I don't think removing it would make it run THAT much leaner..
Old Sep 13, 2000 | 01:30 AM
Skunky's Avatar
call dynojet or go to there website www.dynojet.com and get a bigger main jet.. THey are cheap.... I live here in vegas and just ran down and picked up a spacer...
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
