Ignition switch problem
Old Jan 6, 2005 | 04:10 PM
new2atv's Avatar
Default Ignition switch problem
'01 Xplorer 400 4x4
Last weekend I was out riding and we stopped for awhile and I turned the key off. When I went to turn it back on, it was really hard to turn and I broke the key off. It had been getting gradually harder to turn over the last month or so but I figured it had to do with the cold weather. Once i get the key out, is there some kind of lubricant i can put in the switch to make it smoother? If so, what do you recommend? If not, what can I do or what should I look at from making it turn so hard?
Old Jan 6, 2005 | 04:22 PM
brainiac213's Avatar
i suggest that you get that ignition off of there and either take it apart and clean it or get a new one. i dont think that any lube will fix the problem if you are breaking the key off.
Old Jan 6, 2005 | 06:00 PM
new2atv's Avatar
I was afraid I'd have to replace the ignition switch. I was hoping to find a work-around though. I guess I'll start looking for a replacement switch. Thanks for replying.
toonces
Oct 16, 2019 12:11 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
Daryl Devine
Technical and How-To Articles
Jun 8, 2015 08:59 AM
