TROUBLE!! HELP !!
Old Sep 13, 2000 | 11:28 AM
TurfBlaster's Avatar
I have a Blaster with stock motor, aftermarket pipe and silencer and airfilter. It was running kind of rich (chocolate brown plug) before I installed a new set of reeds and a reed spacer. I started it up and it ran for about 20 seconds then it died. It was out of gas. So I put more in and now it won't start at all. I check the plug and it is wet so it is getting gas and I am going through new plugs. Could it be that the new reeds and spacer could have made it even richer so it's fouling before it can even fire??? Or should the reeds and spacer make it leaner, I don't know?? HELP!!
Old Sep 13, 2000 | 11:33 AM
2001banshee's Avatar
Yeah, you are really running rich after putting in a new set of reeds. The aftermarket reeds are allowing more fuel and air through than stock so you need to jet down at least probably a couple of sizes. I had the same problem with my Banshee when I installed new reed valves but I went down a couple of sizes and that fixed the problem.
Old Sep 13, 2000 | 11:37 AM
How does the Reed spacer affect ?
Old Sep 13, 2000 | 12:23 PM
I have checked the obvious and it does have a good spark.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
