Launching at Drags
Old Jan 10, 2005 | 09:17 PM
Oldmanracing's Avatar
Default Launching at Drags
Two Questions based on 300 ft dirt drags.
What gearing and tires work best for a slighly modded DS?
Which gear do you start out / has worked best for you and why?
Old Jan 11, 2005 | 12:12 AM
MrMeaner's Avatar
What type of soil. Loose dirt, sand, hard pack, stickey, etc.
Old Jan 11, 2005 | 09:04 AM
Soils are usually hard to firm
Getting traction out of the hole is the issue and too much spin when shifting into second gear.
Old Jan 11, 2005 | 09:08 AM
omahapredator's Avatar
try starting in second....it gets rid of alot of wheel spin
Old Jan 11, 2005 | 11:56 AM
sam's Avatar
sam
second gear for sure you will lose too much speed in 1st. you will be playing catch up. and 300 goes really fast Ive learned this lesson( I lost to a kaw 700 ) to much spin and no speed out of the hole. The following week I started in second and smoked him. I also recomend a 14t for 300' and I also ran 4 snows. also lower the quad. make the rear lower and as soft as possiable. you can launch much harder w/ the quad slamed. See pics
Sam
Old Jan 11, 2005 | 08:31 PM
With the 14T sprocket are you using a 20 or 22 inch tire?
Are you shifting 2 or 3 times?
With 4snows do they grow and hit your fenders?
Old Jan 11, 2005 | 09:32 PM
sam's Avatar
sam
22" 4 snows, Im shifting into 5 at the 300' line or just b4, no hitting the fender even w/ my lard a$$[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 11, 2005 | 09:49 PM
SAM,
Looking at your pics it looks like you are running radials on the rear, for normal riding.
Did you ever lower the air pressure on the radials to 1 1/2 #'s and try them at the drags?
Are the 4snows just that much better?
Old Jan 12, 2005 | 12:59 AM
MrMeaner's Avatar
I really like the 4 Snows but we ran a while back and the surface was hard with some tiny little bits of rock and the radials worked better. For loose dirt the 4 Snows rock. I also lauch in 2nd with a 15 tooth front sprocket. If you must use 1st dont over rev. I usually shift quick out of 1st. Also 1 last tip as soon as shes out of the hole get your butt back over those tires.
Old Jan 12, 2005 | 08:20 AM
sam's Avatar
sam
since those pics I ve went to kenda Klaws and love them. the radials were about half gone and I was spinning alot out of the hole the 4 snows stop that. I only ran the snows in the drags last year. the klaws grab like crazy as well. I might try them this year.along w/ the 4 snows. I set up a 300 foot strip on my land and had my bro in law time me. I will do that again this year w/ a few tweeks. to see if I can improve on my times.
Sam
