LT80: Help on jetting
Old Jan 11, 2005 | 03:14 AM
bmiliate's Avatar
Default LT80: Help on jetting
Need some help/advice. I have an '89 LT80 with the following mods: DG pipe, airbox with six 1" holes drilled, and removed two rollers on front clutch (per LT80's advice). The quad runs pretty well, but I want to rejet it for: good performance and, more important, bulletproof reliability. My kids ride it in the desert and, a lot of the time, at top speed for several minutes at a time. I'm not a wrench, and definitely have zero jetting experience. Ride at 0-1000 feet most of the time.
Recommendations?
Thanks.
Old Jan 11, 2005 | 10:38 AM
LT80's Avatar
LT80 Expert
What's the plug look like?
I'd guess dropping to a 90 main jet would be fine.
Old Jan 11, 2005 | 12:03 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Recommendations?
Thanks.
If you added a pipe and modded the airbox without adjusting the jets, I'm surprised it'll even run.
If you can cover those holes on the airbox and it runs better, you need to jet up. I'm not familiar with the LT80 carb, but I assume you can adjust (richen) the needle clip position too, Jack?
Usually when you jet up, you need to adjust the fuel screw out for the pilot jet, richen the needle jet and change out the main.
Old Jan 11, 2005 | 01:07 PM
LT80's Avatar
LT80 Expert
No adjustment, except for the needle.
The DG pipe is very similiar in performance qualitys as the stock pipe. The kids like it cuz it's loud.[img]i/expressions/face-icon-small-smile.gif[/img]
He has done nothing to increase air flows (porting) so the his drilled holes that allow dirt in [img]i/expressions/face-icon-small-happy.gif[/img] is of no concern to the jetting IMO.
The LT80 is jetted fat stock.Thus why I recommended the 87.5 as a safe area.
BTW:: stock is 92.5~~ I increase rpm's 45% and run a 77.5 in my motors.[img]i/expressions/face-icon-small-shocked.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 11, 2005 | 01:31 PM
Raptorlegs's Avatar
T Rex Rider
A 92 does sound fat for a stock 80cc. 77.5 sounds crazy for a modded mini though! [img]i/expressions/face-icon-small-shocked.gif[/img] I'm running a 105 without port work. It won't even hardly run with a 100 or a 110! Falls on it's face at full throttle. That's how sensitive this thing is.
Different breed I recon.
Old Jan 11, 2005 | 02:41 PM
bmiliate's Avatar
Thanks, all.
LT80, you're right - just from a non-wrench looking at it, the DG pipe doesn't look that different than the stock pipe. Probably wasted my money.
I have a stocking over the air filter housing to keep the dirt out, but probably not the water
Thanks, everyone for the jetting advice. I'll go with LT80's 87.5 and see how she runs.
Old Jan 11, 2005 | 04:30 PM
LT80's Avatar
LT80 Expert
Keep your eye on the plug and you'll be fine.
Old Jan 11, 2005 | 07:09 PM
hateful's Avatar
we allready ran a 80 main jet with stock motor you should be good with a 87.5 and yes the dg doesnt do much at all for the motor except make it louder.92 is stock jet on our 98 lt .
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
