Pull starter
Old Jan 11, 2005 | 06:00 PM
DGpolaris2346's Avatar
Default Pull starter
I was going to start my TB today so i pulled the pull start and the rope wouldnt go back like its supposed to. So now the rope is just hanging out but if i tap the pull starter housing it goes back in little by little and then i pull it again and the same thing happens. Please help, thanks
Old Jan 11, 2005 | 09:35 PM
bump
Old Jan 11, 2005 | 11:02 PM
Whitedog's Avatar
Youll probably have to take it off unwind it, clean it up with some gumcutter, grease the hub that the spool rides on and wind it back.
Have you got a service manual?
Pigpen7684's Avatar
Recoil spring may be broke or jammed up if mud or water got in it.
Old Jan 11, 2005 | 11:04 PM
Yea i have a service manual. I never really messed with the pull starter before though so i really dont wanna mess it up. If it is the recoil spring is it hard to remove it?
Old Jan 11, 2005 | 11:05 PM
Bradracer18's Avatar
Go slow and be careful(keep watching) when you tear into that thing......sometimes they just go wham and come unwinded......then you have to figure out where everything goes.......
Old Jan 11, 2005 | 11:16 PM
Pigpen7684's Avatar
Yea good luck with it, it happened to me on my old 1990 Trailblazer and the spring unwound on me not fun at all
Old Jan 12, 2005 | 01:41 AM
BigBadScrambler's Avatar
That recoil spring is a B!TCH to get back on and rewound correctly! I had to take apart mine and clean it for that same reason. Works good now. But I had a heck of a time with that spring. I dont know how much new ones are, but I think that if I do it again, I will just buy a new spring!!!!
Old Jan 12, 2005 | 01:54 AM
jimmypsp700's Avatar
Maybe try spraying some WD-40 in there first to free it up with the rope pulled out.???
Old Jan 12, 2005 | 06:34 AM
lukaka's Avatar
Is it kept inside or out? If outside you might just want to take it in and let it thaw out. With the Rain/ ice/ snow I'm assuming you have like me it might just need to warm up to let loose.
