Mountains on a raptor
Old Jan 12, 2005 | 10:03 PM
DustyTrails78's Avatar
Default Mountains on a raptor
I enjoy riding on rough trails that are more for 4 wheelers, on my raptor. The problem I have is with ground clearance in the rear end.
I was planning on buying some 25 or 26 inch tires so I can get more clearance out back. If I do this I'll also place wheelspacers all around. My questions are what type of tire should I buy (terrain is rocky, mountain, muddy, forrested),and what size sprocket I should go to for the front and rear. Need the help.
Old Jan 12, 2005 | 10:22 PM
86LT250RFatty's Avatar
ha ha! dont put 25" on your raptor it would look so goofy!
Old Jan 12, 2005 | 10:28 PM
2FAST4URASS's Avatar
I would get some GBC GATORS BIG LUGS SPACED FAR APART + THER JUST 53$ THATS A STEAL AND FOR GEARING IF YOUR NOT WORRIED about top end change the front to a 12 tooth to get the verry most out of the bottom. http://www.rockymountainatv.com/Prod...v?pid=00017593
Old Jan 12, 2005 | 10:39 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
The terrain you are describing and the size of tires you want are for a utility, I don't think they make 25" for a sport quad, the highest I think is 22", correct me if I'm wrong. And since you wont be reaching your top speed in rough terrain, I would say go 12 on the front sprocket for more push in the start. The tires I would highly recommend are the ITP Holeshot XCT, the have a 6 ply rating to resist more punctures, and they are 22".
Old Jan 12, 2005 | 10:48 PM
2phast4u's Avatar
yeah they dont make 25 inch tires for asport quads but i can get most mud tires in a 22 inch to fit your quad lik the gators do a search on best mudd tire then look it up n many different atv stores and see what sizes they have r order derectly from the company and if your worried about ground clearence a cheeper way would just get some nice think armor underneath the beast
Old Jan 13, 2005 | 12:17 AM
maddog56's Avatar
It doesnt matter if they make 25" or whatever size for sport quads, you can still put them on.
The problem is that the raptor cant take larger than a 22" tire without removing heel guards and even that only gives you limited clearance. You will need a longer swingarm if you go real big on the rears.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
