header ?'s
Old Jan 12, 2005 | 11:18 PM
2phast4u's Avatar
Default header ?'s
i was just putting my warrior back together and my dad over torqued the head bolts and the studs broke luckfully w/ a lil strenght(thank good my dad works out) vise grips and some wd-40 we got the broken parts out but i cant find the replacement studs ne where does ne buddy no where i can fine them or what else would work? or am i SOL
Old Jan 12, 2005 | 11:25 PM
LivinInVegas's Avatar
Default header ?'s
If the dealer does'nt have them the check an engine rebuilding shop, or your local machine shop. Good luck.
Old Jan 13, 2005 | 08:20 AM
D3athShad0w's Avatar
Default header ?'s
Check the dealer the part number is 90116-06503 (im holding the studs in my hand right now) it will probably cost about 5 bucks for the two and the bolts for them... If you cant get it there you can order it from alba's big OEM parts site located here:
http://216.37.204.206/alba/Yamaha_OEM/YamahaATV.asp
*Its under the Cylinder Head category Ref# 6
Old Jan 13, 2005 | 11:25 AM
Dfitz's Avatar
Default header ?'s
On my son's raptor it has a DMC exhaust, that loves to bust the studs. I took them out and used bolts. Haven't had a problem. I'm trying to say just use a bolt. .50 or $10.00.
Bigtwin700
Sep 9, 2015 09:32 AM
Stillonit
Aug 5, 2015 07:46 PM
zach1106
Jul 31, 2015 01:55 AM
426ex
May 20, 2000 02:41 PM
