warrior lights and stator output
Old Jan 13, 2005 | 12:44 AM
mudmaster250's Avatar
Default warrior lights and stator output
my friends got a 02 warrior and were getting a set of 55 watt driving lights to put on it. my questions are: whats the stator output? what wattage are the stock lights? were gonna wire it up so that the stock high beams turn o when we switch to low and the driving lights turn on when we switch to high. thanks for the help guys,
scott
Old Jan 13, 2005 | 08:14 AM
D3athShad0w's Avatar
I have no clue what the output capabilities are but Yamaha does offer a lighting upgrade for the Warrior to 55watt HALOGEN bulbs & PIAA lights.
http://www.yamaha-motor.com/accessor...983/All/1.aspx
Old Jan 14, 2005 | 02:26 PM
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
The stock headlights are 35 watt in hi or low beam. Watch out for getting your switch between hi and low....it melts the bulb base.
You'll need to rewire some stuff. IIRC, the yellow wire to the lights is the hi beam. The others are for ground and low, but I don't remember the color.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Jan 15, 2005 | 12:46 AM
Old Jan 15, 2005 | 01:08 AM
hondabuster's Avatar
The specs are 17 amps at 8000 rpm and 13 amps at 3000 rpm. So 13 x 12=156 watts at 3000 rpm and 17 x 12= 204 watts at 8000 rpm.
Old Jan 15, 2005 | 01:26 AM
YFZ450kid's Avatar
scott
dont connect it through that switch, run your own, the fuse cant handle the added stress of higher wattage bulbs... just run a hot wire from the battery to the lights, with a switch and fuse in route of course... it works better then you can run the stock high beams and the aux lights at same time, adjusting the angles for best lighting everywhere.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
