Trail blazer 250 mid-top end bogggg
I have an 01 trailblazer. 0-half throttle it runs perfect. Half-full throttle it boggs to almost stalling.
- Carb/jets are clear
- Air filter on or off same result
my friend thinks its electrical. There are some sensors for the throttle, reverse and low oil.
Anyone heard of this issue?
thanks[img]i/expressions/face-icon-small-confused.gif[/img]
I'm at sea level. What should the main jet be? Someone toldme to try a 110. I dont know what stock is. There is a 130 (if I recall correct) in it now. Also, what is the correct needle position?
thanks
Stock main jet is 130. unplug your reverse limiter i bet that will clear things up it happened to me i thought it was the jetting the whole time and it turned out the reverse limiter got water in it and it would bog in forward after going past a certain rpm.
thanks I'll keep that mind. I just got off the phone with my mechanic. He claims the issue is fixed. He stuck a 110 in it and now its solid.
thanks for all the replies!
