04.5 700 "auto" 4X4
Old Jan 15, 2005 | 12:16 AM
StockSPHO's Avatar
Default 04.5 700 "auto" 4X4
Well the easiest way to explain it is this,
My 700 Sportsman (04.5 carb) has about 1500 miles on it and 200 hours. It has had all it’s services done on time and is not abused.
This is what happens. I will have it in two (2)-wheel drive and if I am on ice and hit the gas as soon as the tires start really spinning the 4x4 engages!!!!! With a bang I might add!
I put it in 4x4 and that works fine? Turn it off and it is definitely off.
The dealer tells me the magnets spinning in the front-end fast will cause it to engage even in 2-wheel drive? I also have a second same 04.5 700 non EFI with only 50 hours on it. I can sit on the ice and spin the rears till the cows come home and the front won’t kick in unless I switch on the 4X4?
Any ideas!
Mark
Old Jan 15, 2005 | 02:46 AM
Polaris500HO4x4's Avatar
you may need to change the hub fluid in the front diff case... there is very little so it collects water and dirt easily.. try this its real cheap, i would recommend polaris premimum drive hub fluid or something very similar like an ATF. if this doesnt work you could have a magnitized plate in your hub causing it to engage, then your gonna need your dealer to help ya out
Old Jan 15, 2005 | 10:06 PM
RobRuf's Avatar
I just went thru a similar thing but I agree with 500ho change the fliud... I also read if the hub is overfull it will engage as well... By the way HO, I changed it and all is good
Old Jan 16, 2005 | 12:31 AM
StockSPHO's Avatar
Just had a complete service done, all fluids................ Low or Hi range, on ice get the back tires spinning 20 MPH or more before the machine is moving more then say 5 MPH and the front end engages! I was on glare ice today with "fresh" fluids and put the brakes on and leaned kind of forward just to get the tires to break free. Well they did...... and the front end kicks in?????? Like I said high or low if I get the back tires going more then say 15 MPH faster then the front bang AWD comes on!
I was going into turns trying to power slide around and bang the front end would kick on again?
Any one?
MArk
Old Jan 16, 2005 | 04:20 AM
Any one?
MArk
i read something aobut your armature plate becoming magnitized causing the awd to kick in whenever it feels like... if its still underwarrenty have you dealer or better yet someone who cares see if that might be the problem
chuck1177
Jun 30, 2015 09:52 AM
OffRder15
Dec 29, 2004 09:45 PM
davenh
Nov 22, 2004 01:01 AM
Dobie
Aug 24, 2004 12:07 AM
E
Nov 30, 2003 05:36 PM
