Nitrous oxide on a raptor?
Old Jan 15, 2005 | 06:28 AM
nitrousoxide's Avatar
Default Nitrous oxide on a raptor?
Hi guys!
What do you think about nitrous oxide system on a raptor?
How long keeps the engine by using nitrous oxide?
Possibly who has notion of it????????????????????????????
Old Jan 15, 2005 | 09:57 AM
mick660r's Avatar
with a 727 you would want to put bigger jets in before you put nitrous on
i am surprised you dont have a hole in your piston
i was running the same main jets as you on just a exhaust and air filter and had to jet to a
150/155 because it was too lean
if you put bigger main jets in it will feel like you have nitrous because your bike will go much faster
Old Jan 15, 2005 | 10:59 AM
Voodoothenoob's Avatar
I would get your Jets dialed in before you add nitrous
a 727 should fly
those jets you have is what peeps have in their stock motors and a pipe
try 170/175
link to jet sizes and conversion chart below
http://www.roadstarclinic.com/TechTi...Conversion.htm
many think nitrous is cheating and dont get any respect or races, so that means it probably works really good[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 15, 2005 | 01:33 PM
PolishCowboyPL's Avatar
You can keep your engine as long as you want, so long as your nitrous and engine is tuned properly for it, so it doesn't run super lean and burn stuff up.
Old Jan 15, 2005 | 01:47 PM
maddog56's Avatar
There are many members here with Nitrous on their bikes. There are two types, wet and dry. Do a little searching on the Boondocker's and NOS systems kits and you'll find lots of answers.
Old Jan 15, 2005 | 01:57 PM
D3athShad0w's Avatar
Dry system = bad - To much **** that can go wrong. Install a wet system with a direct inject into the intake manifold with a fuel pump that guarantees your ratio.
Old Jan 15, 2005 | 02:19 PM
Hey guys!
I don´t understand that our stock raptor in USA has 35 HP. Here in germany, if you get a brochure about ATVs (regarding raptor) you can see the raptors are registered with 47 Hp!
Or talk everybody of you in each case about "KW"(1 HP=0.736 kw)???
Old Jan 15, 2005 | 03:01 PM
HughJazz's Avatar
47 is at the crank
Old Jan 15, 2005 | 05:04 PM
bulldogz400's Avatar
Originally posted by: HughJazz
47 is at the crank
Yep, 47HP at the crankshaft, 35HP at the rear wheels.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Ask the Editor
Sep 14, 2015 08:57 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
