faster 300ex
Old Jan 15, 2005 | 03:55 PM
300exridingboy's Avatar
Default faster 300ex
how can i make my 3ooex faster without spending a lot of money?
Old Jan 15, 2005 | 04:01 PM
clover's Avatar
change the gearing,but you will lose some bottom end.
Old Jan 15, 2005 | 04:02 PM
is there any thing else i can do
Old Jan 15, 2005 | 04:04 PM
i want to make my 300 beat my dads 400ex?
Old Jan 15, 2005 | 05:25 PM
95wolv's Avatar
Pipe and filter will help, then it can pull taller gears,but you will only be hitting about 55 mph or so, to keep up with a 400ex, you are looking at a big bore, and cam to stay with him, but that will be pretty iffy. The money you would spend to keep up or beat a 400ex would be better spent buying a bigger quad. There is only so much you can do with a 282 cc motor.
Old Jan 15, 2005 | 05:49 PM
WISTECH's Avatar
You will have to let the air out of the tires on the 400ex ,pour rotten gas in the tank,and adjust the throttle so it only opens half way . That the only way a 300ex will beat a 400ex for not a lot of money.
Otherwise a 352,406 kit,major porting,big valves,big carb,exhaust,cams,(around$1500to$2000) will get it to beat a stock 400ex.
With that power you will need to throw a lot of cash at the suspension to keep the tippy 300 on its wheels. All in all keep it stock , get a 400ex or the many faster quads and save yourself the trouble.
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
