balster help
Old Jan 15, 2005 | 06:49 PM
stealthrt's Avatar
Default balster help
after a month of taking my blaster apart i finally got time to put it back together, i replcaed my throttle cable with a new one, i have the twist and not the thumb, but it has not been started for over a month, i put a fresh plug in and tried to start it but it wont start, and my throttel cable just does not seem right, it feels like its jamming up on something, are there any tips for getting it started after it set for this long?
Old Jan 15, 2005 | 07:18 PM
poopy's Avatar
i dont know much about blasters or two strokes but you can put fresh gas in it. and you can clea your carb out.
Old Jan 15, 2005 | 07:30 PM
fastblaster00's Avatar
when u try to kick it does it seem like the throttle is wide open? cause maby when u put it back togeather the throttle was stuck open and thats y it dont start. make shore the gas and key is on and choke it... it sounds stupid but usily its stupid things that cause problems. try push starting it if u still cant get it to start. put it in 2nd and push it. or pull the clutch in and dump it.... if the motors cold ur better off leavin it in gear and pushing it.
Old Jan 15, 2005 | 09:37 PM
stealthrt's Avatar
i took the key off when i 1st got it so i does not have one of those, i am gonna go take apart the carb again and double check all of my connectios, just ot be sure
Old Jan 15, 2005 | 10:07 PM
Banshee392's Avatar
It may be bad gas...I had the same problem...
ragnredneck
Jan 2, 2008 12:23 AM
travism
Aug 29, 2007 06:48 PM
michaud321
Jul 24, 2007 12:57 AM
fastestkidaround
May 26, 2006 08:46 PM
