Squishy Brakes 400EX
Old Sep 14, 2000 | 01:36 PM
mntrailrider's Avatar
Can I adjust my front brakes for this? The brakes don't even actuate until they're half way to the bars and If I pull harder the lever will touch the bars. The front tires never lock up. This can't be normal, can it?
Old Sep 14, 2000 | 02:33 PM
Skunky's Avatar
No that is not right ...Sounds like you might have a loose brake tit that let some air in.. Or some lose part on the brake line... You got fluid in the brake reservoir? After all that is checked... Time to bleed the ol brakes... You will have to bleed them.
86atc250r's Avatar
Hydraulic disc brakes have no adjustment. Check for contamination of the break disc & pads (lubricant, etc). Bleed the brakes....
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
