anyone know how to get a rincon cold weather
Old Jan 17, 2005 | 09:42 PM
hondaaboy's Avatar
Default anyone know how to get a rincon cold weather
Does anyone know how to start a rincon in weather below 0 F.
Old Jan 17, 2005 | 10:15 PM
Duramax's Avatar
Use the fuel primer and then choke.
Old Jan 18, 2005 | 12:09 AM
hondaaboy's Avatar
how do i use the fuel primer.
Old Jan 18, 2005 | 01:03 PM
extremerider2811's Avatar
we've had severely cold weather around here in wisconsin but i keep my honda utility (trx450fe ESP) in the warm garage, but it is about 10 degrees warmer in there but still cold, i just put the choke on and push the button and wait for it to start and let it warm up for about 10 minutes before i give it any rev, because i do not want to risk damage to the motor.
it will list everything in your manuel so look in there how to use the primer.
Old Jan 18, 2005 | 03:01 PM
Cirviver's Avatar
Unless they changed it, it should be a black **** on the side of the carburator. Just push it in a few times before you try to start it.
Old Jan 19, 2005 | 03:29 AM
Gimpster's Avatar
I believe the side cover has to be removed to get at the ****. Try not to over use it, more than 2 or 3 pumps can foul a spark plug.
( hopefilly the weather will change there, like it did here. We were double digits below zero yesterday, and today it warmed up to 44 degrees above. HEAT WAVE !! LOL )
----- Gimpster -----
Old Jan 19, 2005 | 09:28 AM
dzzy's Avatar
In -0 weather, I've had the best luck with 2 slow pushes on the primer, full choke and keep your hand off the throttle. No more primer than that though, unless maybe it's -20 or colder. Other things are important too...like a good fully charged battery, a spare plug, and Winter weight oil.
ultangler
Nov 30, 2024 01:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
