Dial a jet?
Old Jan 18, 2005 | 12:08 AM
Vuker's Avatar
Default Dial a jet?
Worth it or Full of it?
Old Jan 18, 2005 | 11:15 AM
dinaps's Avatar
Default Dial a jet?
Dirtwheels did a review on it, I think it was last months issue. They said it worked pretty well, especially if you change elevations quite frequently.
Old Jan 21, 2005 | 07:30 PM
TriSum's Avatar
Default Dial a jet?
They definately work. We use them here on the Dyno to to "clean" up the air fuel curve. I don't know if you will feel any performance difference, but it may keep you from leaning out at a lower elevation. Definately get it tuned on the Dyno. Some companies recommendations are not even close to what they should be for every quad. It's kind of scary.
Old Jan 21, 2005 | 09:31 PM
Vuker's Avatar
Default Dial a jet?
thanks, i was just wondering if its worth getting or if i should just go with a regular jet kit?
Old Jan 21, 2005 | 10:03 PM
dinaps's Avatar
Default Dial a jet?
If you're planning to re-jet anyway, I would recommend it. The good thing is that once it's installed, you don't have to open up the carb for future upgrades or drastic elevation changes. You can turn the dial and adjust the jets in seconds.
Old Jan 22, 2005 | 12:07 PM
zippy's Avatar
Default Dial a jet?
go on ebay and do a search for a jet kit that is NOT dyno jet. there are some kits that offer alot of jets for a reasonable price. 9 jets for $23
Old Jan 23, 2005 | 04:24 PM
TriSum's Avatar
Default Dial a jet?
We use both a "Kit" and "DAJ", since we have the Dyno available to do our tuning we use all off the parts (IE: Jets, Needles, DAJ) to get the quads spot on. If you have the option, the Dyno is the only way. For example, I did one last week, a Predator, that had a slip on, filter and cut air box. This was already tuned by the slip on manufacturer (BIG company). It was soo lean at points my air fuel equipment wouldn't even read it. When I was finished, it picked up 2.2 additional HP and was safe in the AF department. Be careful.
STLyamwar
Jul 25, 2020 04:44 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Mphillips
Jun 26, 2015 03:52 PM
coolhuh
Jun 24, 2002 04:05 PM
sparkys
Jan 30, 2002 10:31 AM
