cdi troubles
Old Jan 18, 2005 | 05:41 PM
Badbone's Avatar
Default cdi troubles
I have a Polaris Sportsman 500. I have no spark during cranking. It sparks once when start switch is released. It acts like the ignition is being grounded by a safety device. Does anyone have troubleshooting expertise on Polaris cdi ignitions?
Old Jan 18, 2005 | 06:57 PM
Polaridoo's Avatar
Read this similar thread and see if it helps.
http://forums.atvconnection.com/mess...keyword1=spark
Old Jan 20, 2005 | 11:41 AM
Badbone's Avatar
Thanks, I read the thread. I have a fairly new battery. While cranking I did have a battery charger connected. I've also pulled the hand crank and still have no spark. During cranking I have about 40 v on two of the wires comming from the stator and about the same on the wire going to the coil. The frequency on the wire feeding the coil is about 34Hz. I think something is grounding me out, just don't know what. I don't what the readings should be on the different wires or how the backup module or voltage reg affects the ignition.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
