300ex
Old Jan 18, 2005 | 07:38 PM
Thunder53's Avatar
Default 300ex
ok i have a 300ex and a friend of mine just got a 250x and i don't know if i can beat it and i want to do something to my quad to make it a little faster but i can't spend a whole lot of $$ so if you could tell me something cheap i could do that would be great. I ride on just about everything favs are mud and tracks sometimes me and him drag but i ride trails and everything love the dunes just want something
Old Jan 18, 2005 | 07:57 PM
Ntrx250xJ's Avatar
Default 300ex
The 250x and 300ex basicly have the same engine. Only 2 differences are that the 300ex is electric start and it has 4mm more stroke on the crank. Everything else about these engines are mostly the same. when my 250x was stock i drag raced a few 300ex's. Stock for stock the 300ex's ive raced we were almost side by side the whole way to full out 5th gear. the 300ex had a slight lead everytime. So there pretty close to being even. As far as cheap mods i guess a better air filter, take the lid off, and find a 350x atc air tube.(the 350x atc had a bigger air tube between the air box and carb. Ur might have to rejet ur quad for that lil bit more air but maybe not. its up to u to tune it correctly. Id definatly find parts off of ebay. If ur lucky u can find a used after market exhaust for cheap. That should be enough to be slightly quicker if the 250x is stock.
Old Jan 18, 2005 | 09:09 PM
Dirtmomma's Avatar
testing testing 123.
Default 300ex
You could try a cam also but the pipe,filter,lid off of air box does make a big difference [img]i/expressions/face-icon-small-happy.gif[/img] good luck have fun!!
Old Jan 19, 2005 | 02:36 PM
300exridingboy's Avatar
Default 300ex
get a smaller front sproket by 2 teeth and get a larger back sproket by 1 tooth this will give you more top end speed, bye the way you should be able to beat a 250x.
Old Jan 19, 2005 | 07:00 PM
Thunder53's Avatar
Default 300ex
thanks for all the info i will check ebay for them [img]i/expressions/face-icon-small-smile.gif[/img]
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
