Kodiak bogging in the deep
Old Sep 14, 2000 | 07:40 PM
Kerplunk's Avatar
My 2000 Kodiak seems to bog a little in deep water or mud. I put some di-electric grease on the plug but that didn't help. I don't think water is getting in the intake because it's not quite that deep(about the bottom of the head lights), so could it be somthing else?? If that is the problem has anyone put a snorkel on a new Kodiak yet?
Old Sep 14, 2000 | 08:45 PM
frano's Avatar
I've had two situations with my 2000 Kodiak where it appears to be running out of fuel after coming out of deep water. Didn't think much about it until I say your message--maybe there is a problem. I had a similiar problem years ago with my Honda XL 250 and after a couple of years of frustration I found that after a water hole, steam (moisture) would enter the air box and pass thru the filter and lay on top of the jet orifice in the venturi, shutting down fuel flow. After a few minutes the engine would restart like nothing ever happened. Guys that switched to Mikunis solved the problem.
Old Sep 15, 2000 | 12:50 AM
Kerplunk's Avatar
Yea, it's just like a total loss of power. It won't quite stall but won't rev either. I just sit for a second and it's okay.
Old Sep 15, 2000 | 11:07 AM
monk01's Avatar
As a matter of fact, that has happened to me twice. I hit a puddle to fast. I was trying to get the rider next to me wet and didn't know the puddle was that deep. I hit the water, and it just about stopped me, then my quad almost stalled. It spit and sputtered for a few seconds, and then it was okay. The other time it happened I was going through some pretty deep mud when I started to get stuck. I threw it in four and pinned the throttle. I got some good traction and starting going trough pretty fast. The water was shooting all over the place. When I made it through, it started sputtering on me. It did it for a few seconds and then it was okay. It seems weird to me, because I never had a problem with the belt slipping. I thought the intake for the belt and airbox were at about the same height.
Old Sep 16, 2000 | 05:48 PM
km74's Avatar
Is there any cure for that? I have the same problem if I go to fast through water.
Old Sep 16, 2000 | 09:14 PM
JHAM's Avatar
Mine did that at first till I filled spark plug boot full of dielectric gease and no problem since for over 350 miles.
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
