need help with my blaster! please! spark?
alright. i just bought a 91 blaster. it sat for 4 years but ran b4 it was put up. i cant seem to get it started. i rebuilt the carb and put in new reeds. my spark plug boot just kinda pulled out of the plug wire. i snipped a little bit off the plug wire so i can get clean wires. then i screwed the boot back in. put my plug in and kicked it over with the plug sittin on the head. i had spark. everytime. i then put the plug in and put the boot on. the boot had to stretch so it kinda pulled out of the wire a little bit. i got nothing. i pulled it out and i have no spark again. i try and try and try and every once ina while i get a small spark but other than that i have nothing. i have a new coil and igntion switch on their way. but i wanna figure this out instead of throwing parts at it. would the problem be the coil? i also removed the flywheel and cleaned the stator VERY well. has a very strong magnetic pull and everything. i tried using a test light but im not sure how good the light is or if it would even work but put it to the incoming wire (orange) to the coil and i didnt get any light at all. i dont have a volt meter so im kinda screwed there. i have to do it the old fashion way. what do you think? i hope its the coil but the way everything else on this think has gone its probably not. any help or information you coudl give me would be awsome or maybe point me in the direction of a blaster manual i can download. thanks!
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
