Hillard Clutch problems?
Old Jan 20, 2005 | 06:43 AM
hdnvn's Avatar
Default Hillard Clutch problems?
hey, when riding with a couple of guys I've been told that my right front wheel on my Polaris Sportsman 500 isnt driving full time, it kicks in once in a while. I've filled the hub up with the factory stuff, one friend suggested that maybe overfill was the problem. I havnt reduced the amount yet, thought I would get some feed back here first. The axle on that side is brand new. Thanks for suggestions...
Old Jan 20, 2005 | 12:15 PM
Polaris500HO4x4's Avatar
amrature plate may be somewhat warped.... very little tolerance in there
Old Jan 20, 2005 | 12:22 PM
OffRder15's Avatar
What year is your Sportsman?
If it still has the On Demand hubs, the hubs are filled with fluid through the hex bolt, which should be at the 3 or 9 o'clock position when filled. I would also check to see if the castle nut in the hub is tightened to spec. Also, check the wire leading to the hub to make sure it isn't cracked or torn.
The first thing I would check is the fluid level.
Old Jan 20, 2005 | 06:07 PM
tyler711's Avatar
I think the book says 8 or 4 oclock when filling, but i believe it is personal opinion between the two
skinnyr6
Aug 25, 2023 02:18 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
cornermike
Jul 8, 2015 11:44 PM
