2wd to 4wd conversion?
Old Jan 20, 2005 | 11:59 AM
weewane's Avatar
Default 2wd to 4wd conversion?
my buddy has got a 350 rancher 2wd and he wants to make it a 4wd can it be done and where can he get a kit if they make 1. Has any1 else done this and was it a waste of money? Was there still enough power to get the job done. Thanks for any help
Old Jan 20, 2005 | 01:38 PM
trbizwiz's Avatar
check google for salvage suppliers and find a similar size honday 4x4 maybe you could get the parts off it to make the conversion, but really it will be cheaper to buy a 4x4 quad to fit your needs, also you will probably be disapointed in a 350 4x4 power pulling seed ect.., however that beeing said dont let anyone tell you something cant be done, cause if youre motivated, you will end up with a very original machine. good luck post some pix if you do it (pix of each stage of the conversion)
Old Jan 20, 2005 | 01:52 PM
CTATV's Avatar
Wanted to do it to my trailboss back in the day. I looked into it. there are no "kits" available it would have to be custom and unless your very skilled with fabrication and you have a lot of time to invest it isnt worth trying it, better off getting some new tires or a new 4x4 quad
Old Jan 20, 2005 | 02:11 PM
TeamRF2's Avatar
I'm pretty sure that you would also have to buy a new transmittion if you wanted to do that, or some how rig up your own way to run either a chain or a drive shaft off the primary sprocket up front, then you would have to fabricate them all and then a switch to turn it on or off, ....i think after all that the amount of time and money togeather would be more than the quad.
probly cheaper and easier to just buy a 4X4 used one.
Old Jan 20, 2005 | 03:04 PM
Prong's Avatar
Somebody else asked this a week or so ago. After pricing out the necessary parts for conversion, you're looking at anywhere from $2100-2600 for parts depending on whether you have an ES or Standard shift.
Old Jan 20, 2005 | 05:16 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
A couple of years ago, somebody priced out the parts for the conversion. It was THOUSANDS of dollars. Cheaper to sell the 2X4 and get a 4X4.
Old Jan 20, 2005 | 06:06 PM
SideWinder4x4's Avatar
Yeah someone else asked this same question on another ATV forum so I decided to figure what parts would be involved and how much $$$ it would cost. Below is my response to the original question a few weeks back. As for power, it should be the same if you compare a converted 4x4 Rancher to a factory 4x4 Rancher.....and of course some power will be lost when comparing a 2x4 to a 4x4 Rancher due to extra weight and drivetrain parts being turned. Enjoy the reading it's quite detailed!
First, let me say that your much better off buying or trading for a 4x4 due to the high cost and lots of work involved. On the other hand if you have plenty of money and want a challenge, this is the project for you.
Just for kicks, I checked out the parts manual comparing the difference between a 2x4 and 4x4 manual shift model 2004 Honda Rancher 350 and came up with the following figures:
Please keep in mind that these prices included some parts that would not be necessary to buy if you have the electric shift (ES) models, but they are noted where necessary.
Figures for 2x4 - 4x4 Manual Shift Rancher
Necessary Items - $2015.50
Questionable Items - $593.46
Total Worst Case Price - $2608.96
Figures for 2x4 - 4x4 Electric Shift Rancher
Necessary Items - $1549.55
Total Worst Case Price - $2143.01
Also remember that I feel that these are accurate figures, but there is always a chance for a typo or mistake when you looking at so many different part #'s and quantities of each items....and comparing everything, but it should be very close to being right.
The complete breakdown is as follows:
CRANKCASE ITEMS:
11330-HN5-M00 - COVER, FR. CRANKCASE
91071-KS6-004 - BEARING, RR. SWINGARM PIVOT
91204-HC4-005 - OIL SEAL (20X28X5) (KOYO)
23612-HN5-671 - SHAFT B, FINAL
90453-KZ4-000 - WASHER, THRUST (20X30X1.5)
STEERING SHAFT ITEMS:
53235-HN5-670 - ARM, STEERING
FRONT ARM ITEMS:
51311-HM7-000 - STAY, FR. GUARD - qty.x2
51315-HN2-000 - GUARD, R. FR
51316-HN2-000 - GUARD, L. FR
51350-HN7-000 - ARM ASSY., R. FR. (LOWER)
51360-HN7-000 - ARM ASSY., L. FR. (LOWER)
51370-HN5-670 - ARM ASSY., R. (UPPER)
51380-HN5-670 - ARM ASSY., L. (UPPER)
90111-KT1-780 - BOLT, FLANGE (6MM) - qty.x6
KNUCKLE ITEMS:
42250-HN5-671 - SHAFT, R.
42350-HN5-671 - SHAFT, L.
51200-HN5-670 - KNUCKLE ASSY., R.
51250-HN5-670 - KNUCKLE ASSY., L.
94201-30180 - PIN, COTTER (3.0X18) - qty.x2
FRONT FINAL GEAR ITEMS:
40400-HN5-670 - SHAFT ASSY., FR. PROPELLER
91306-329-000 - O-RING (16X1.9)
41400-HN5-M40 - GEAR ASSY., FR. FINAL
38581-671-003 - JOINT, TUBE
44121-HN5-670 - TUBE, BREATHER (3.5X1050)
50304-KS3-900 - COLLAR, FR. ENGINE HANGER
50350-HN5-670 - BRACKET, FR. GEAR CASE
90151-HC5-000 - BOLT, FLANGE (10X62)
90154-HC5-000 - BOLT, FLANGE (10X48)
90305-HC0-770 - NUT, SELF-LOCK (10MM)
90309-KF0-003 - NUT, FLANGE (8MM)
FRONT BRAKE PANEL ITEMS:
38581-671-003 - JOINT, TUBE - qty.x3 - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
95002-35000 - CLIP, TUBE (C6.5)
95005-35001-30M - BULK HOSE, VACUUM (3.5X1000)(3.5X250)
95701-08016-07 - BOLT, FLANGE (8X16) - qty.x2
95801-08030-00 - BOLT, FLANGE (8X30)
95005-35001-30M - BULK HOSE, VACUUM (3.5X1000)(3.5X120)
95005-35001-30M - BULK HOSE, VACUUM (3.5X1000)(3.5X600) - qty.x2 - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
95005-35001-30M - BULK HOSE, VACUUM (3.5X1000)(3.5X770) - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
FRONT WHEELS ITEMS:
44610-HM5-A80 - HUB, FR. WHEEl - qty.x2
45700-HN5-670 - DRUM ASSY., FR. BRAKE - qty.x2
90305-HM5-A80 - NUT, CASTLE (16MM) - qty.x2
91263-HA7-771 - DUST SEAL (19X22.5X10.5) (ARAI) - qty.x2
91356-HA7-651 - O-RING, BRAKE DRUM - qty.x2
94201-30400 - PIN, COTTER (3.0X40) - qty.x2
96001-06010-00 - BOLT, FLANGE (6X10) - qty.x4
WIRE HARNESS ITEMS:
30410-HN5-671 - MODULE, IGNITION CONTROL DIGITAL(CDI)(DC) - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
32100-HN5-M41 - WIRE HARNESS - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
FRAME ITEMS:
90651-KV6-003 - BAND, WIRE - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
COOLING FAN ITEMS:
19014-HM7-000 - COVER, SHROUD - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
19015-HM7-000 - SHROUD, COOLING FAN - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
19020-HM7-000 - FAN, COOLING - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
19021-HC4-000 - SPACER, FAN - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
19021-VM5-305 - WASHER, CUP - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
19030-HM7-003 - MOTOR, COOLING FAN - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
19031-HA7-671 - GROMMET - qty.x3 - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
19032-HA7-671 - COLLAR - qty.x3 - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
90041-PG6-004 - NUT, HEX. (5MM) (MITSUBA) - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
90111-197-890 - BOLT, FLANGE (6MM) - qty.x4 - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
90673-SB2-000 - NUT, CLIP (6MM) - qty.x4 - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
93894-04020-00 - SCREW-WASHER (4X20) - qty.x3 - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
93913-24480 - SCREW, TAPPING (4X16) - qty.x3 - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
95003-07008-60M - BULK HOSE, VINYL (4X7X8000)(4X7X540) - ONLY NEEDED IF CONVERTING FROM MANUAL SHIFT 2WD
$$$2015.50
ITEMS THAT MAY OR MAY NOT BE NEEDED DEPENDING ON FIT AND PREFERENCE:
FRONT SHOCK ITEMS:
51400-HN5-M41 - SHOCK ABSORBER ASSY., FR - qty.x2
FRONT ARM ITEMS:
90305-HC0-770 - NUT, SELF-LOCK (10MM) - qty.x8
90151-HC5-000 - BOLT, FLANGE (10X62) - qty.x8
FRONT KNUCKLE ITEMS:
90310-HB9-000 - NUT, CASTLE (12MM) - qty.x2
FRONT WHEEL ITEMS:
44650-HN7-000ZA - WHEEL SUB-ASSY., FR. (TYPE1) - qty.x2
44711-HN5-672 - TIRE (24X8-12) (BS) - qty.x2
REAR WHEEL ITEMS:
42650-HN5-M40ZA - WHEEL SET, RR. (TYPE1) - qty.x2
42711-HN5-672 - TIRE, RR. (24X9-11) (BS) - qty.x2
REAR SHOCK ITEMS:
52400-HN5-M41 - SHOCK ABSORBER ASSY., RR.
REAR FENDER ITEMS
80100-HN7-000ZB - FENDER, RR. *R232* (PATRIOT RED)
EMBLEMS:
87123-HN7-000ZA - MARK, RR. (4X4) (TYPE1) TOOLBOX 4X4 LOGO
FRONT FENDER 4X4 LOGO - DEPENDS ON COLOR
$$$593.46
I hope this helps you out.
Later!
shimanok2
Jan 29, 2016 07:37 PM
Nazz26
Jul 30, 2015 11:51 AM
KingDingalling
Jul 29, 2015 10:55 AM
toonces
Jul 11, 2015 12:01 PM
Tomg
Jun 10, 2000 07:57 PM
