Cold weather..my preddy sucks..yours?
Old Jan 20, 2005 | 06:30 PM
heatseeker8's Avatar
Default Cold weather..my preddy sucks..yours?
Had to use a tow strap and a Yamaha to get the preddy going today...This thing is cold blooded..the Yamaha with a main jet that is to large and a pilot that is to small NEVER gives me problems starting in the cold weather.
Old Jan 20, 2005 | 07:13 PM
Bradracer18's Avatar
Is your's jetted properly?? They do pretty bad in the cold......I pull mine into the shop(heated) then start it up in about an hour......works a lot better.
Old Jan 20, 2005 | 07:38 PM
Umm..its stock..so yeh..I hope so..and there shouldnt be anything in obstructing the carb..it started fine once pulled around
Old Jan 20, 2005 | 07:46 PM
so yeh.....what...........Do you actually think they all come jetted properly, for everyone's altitude and temperature?? nope.......so you might want to check it, but either way, they do start hard!!!!
Old Jan 20, 2005 | 09:39 PM
Pigpen7684's Avatar
What do you think of your 05 Troy Lee Pred when you actually get it started?
I'm lookin to buy that exact quad come spring please write a little review on it tell me if it's worth gettin.
Old Jan 20, 2005 | 10:38 PM
mtgs04's Avatar
I have a mildly massaged pred and I usually don;t have any starting problems in the cold unless I let my battery sit for to long, If you continue to have problems maybe try re-jetting ( we had to change a friend of mines pilot jet to get it to start in the cold)or even partially covering the tube that enters the airbox a little bit when you try to start, also check to make sure your choke is working properly I have read that sometimes they can stick a little
Old Jan 20, 2005 | 11:52 PM
Sceiks's Avatar
I had the same problem with hard starting until i found the problem. Where the choke cable goes into the carb there is a brass slug attached that when you pull on the choke it slides in and out of the carb to richen and lean the mixture. Mine was froze in the Lean (no choke) postion in the carb housing. My cable would still move as if it was working but without richening up the mixture. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 21, 2005 | 12:37 AM
RAJ's Avatar
RAJ
I went out today and started mine right up....I have the stock pj and the mj is a 172.5, with the air screw turned out 2.5 turns.
Old Jan 21, 2005 | 02:03 AM
rob02's Avatar
Its about 15 to 20 degrees out rite now and i have no prob starting it up id say try rejetting it
Old Jan 21, 2005 | 08:18 PM
PaulPud's Avatar
its 19* today and i had a problem getting it running. the battery seemed weak so i put my jumper pack on and it fired right up. i think the cold is killing the amps in the battery.
ultangler
Nov 30, 2024 01:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
