HELP!!!!!!!!!!
Old Jan 23, 2005 | 11:37 PM
thumper650's Avatar
Default HELP!!!!!!!!!!
How go you move the battery behind the air intake. Do you hav to get a new air box let me know!!!!!!!!!
Old Jan 23, 2005 | 11:43 PM
DuneRider650's Avatar
I ride a little here and there......
i think the guys that were doing that were getting illuminum airboxes
Old Jan 23, 2005 | 11:46 PM
thumper650's Avatar
Who makes thos and how dos it not hit the k&n
Old Jan 24, 2005 | 01:44 PM
JEFFROE's Avatar
i cut off the batt brackets and bolted (the stock) battery craddle under the seat up high ( no more tool kit ) enough so you can't even see the batt at all. must use a gel batt because it will be laying on it's side. throw away the stock air box and go with a snow pre-charger direct mount K/N air-filter and you'll be all set.
Old Jan 24, 2005 | 02:57 PM
DSengineer's Avatar
Has been here a long time!
Do a search on "PPD". THey make a nice airbox that houses the battery and rectifier. Johnnyairtime has pics on his site
Old Jan 24, 2005 | 03:44 PM
thumper650's Avatar
whats so grate about movin your battery to your airbox any way
Old Jan 24, 2005 | 04:05 PM
OregonDunePatrol's Avatar
Thumber,
The only thing good about moving your battery over is getting off the side. It is a little ugly there, and if you ride rock trails the potential of battery damage is probably a little more right there on the side. Honda took care of this problem by putting a rubber drape over the side mounted battery. If you do move the battery to the inside, you'll still have quite a bit battery support frame members attached to the subframe. You could cut that off and re-powder coat or paint your subframe. There are various battery boxes out there that can dress up the battery if you decide to leave it there.
Marky
Old Jan 24, 2005 | 08:00 PM
thumper650's Avatar
cool thanks
Old Jan 24, 2005 | 08:13 PM
shmee's Avatar
iv seen the carbon fiber batt cover from alba--looks good!
Old Jan 24, 2005 | 09:04 PM
atvaddict01's Avatar
Nice chrome one on ebay.Anybody see one in person?
