800EFI CV boots
Old Jan 25, 2005 | 06:50 PM
ambrosie's Avatar
Default 800EFI CV boots
Can someone tell me if all eight cv boots are the same part #
Old Jan 25, 2005 | 07:16 PM
GE4x4's Avatar
No there not. You can look here for a complete parts list.Polaris parts list
Old Jan 25, 2005 | 07:17 PM
GE4x4's Avatar
no they are not. Here is a complete parts list.SP800
Old Jan 25, 2005 | 10:35 PM
THECVMAN's Avatar
If you click a drag the parts list on the left of that listing a little further you will see "Usage". Click on that and you'll see all of the other vehicles that use the same part number. And as you can see the boot is the same as the earlier models and is available (see list below). If you need more info PM me.
Danny (thecvman)
: 2201015
Year Product Model Assembly
SERIES 11 PPS UTV 2X4/4X4/6X6 FRONT DRIVE SHAFT - C11RD50AA/AB/C11RF50AA
SERIES 11 RGR RANGER FRONT DRIVE SHAFT (4X4)(6X6) - A11RD50AA/AB/A11RF50AA
SERIES 10 PPS PTV 6X6 DRIVE SHAFT - C10CL50AA
SERIES 10 PPS UTV 4X4 FRONT DRIVE SHAFT - C10RD50AA
SERIES 10 RGR RANGER FRONT DRIVE SHAFT - A10RD50AA
SERIES 10 RGR RANGER 500 6X6 FRONT DRIVE SHAFT - A10RF50AB
2005 ATV SCRAMBLER 500 4X4 DRIVE SHAFT - A05BG50AA/FA
2005 ATV SPORTSMAN 6X6 DRIVE SHAFT - A05CL50AA
2005 ATV SPORTSMAN MV7 DRIVE SHAFT, FRONT - A05MH68AP
2005 ATV SPORTSMAN 800 EFI DRIVE SHAFT, FRONT - A05MH76AC/AU/AW
2005 ATV MAGNUM 330 4X4 FRONT DRIVE SHAFT - A05CD32AA/AB/AC
2005 ATV ATP 330 4X4 FRONT DRIVE SHAFT - A05JD32AA
2005 ATV ATP 330 4X4 QUAD FRONT DRIVE SHAFT - A05JD32EA
2005 ATV ATP 500 4X4 FRONT DRIVE SHAFT - A05JD50AA/AB/AC
2005 ATV SPORTSMAN 400 FRONT DRIVE SHAFT - A05MH42AB/AG/AH
2005 ATV SPORTSMAN 500 HO/INT'L FRONT DRIVE SHAFT - A05MH50AB/AC/AG/AH/FB
2005 ATV SPORTSMAN 600 FRONT DRIVE SHAFT - A05MH59AK/AN
2005 ATV SPORTSMAN 700 EFI FRONT DRIVE SHAFT - A05MH68AC/AS/AU/AW
2005 ATV SPORTSMAN 700 FRONT DRIVE SHAFT - A05MH68AK/AN
2005 RGR RANGER 2X4,4X4,6X6 FRONT DRIVE SHAFT (6X6) - R05RF50AA
2004 ATV A04BG50AA SCRAMBLER 500 4X4 DRIVE SHAFT - A04BG50AA/FA
2004 ATV MAGNUM 330 4X4 DRIVE SHAFT - A04CD32AA/AB/AC
2004 ATV A04CH42AA SPORTSMAN 400 DRIVE SHAFT - A04CH42AA/AE/AG
2004 ATV A04CH42AQ SPORTSMAN 400 DRIVE SHAFT - A04CH42AQ/AR/AS/AT/AV
2004 ATV A04CH50AA SPORTSMAN 500 DRIVE SHAFT - A04CH50AA/AC/AE/AG
2004 ATV A04CH50AQ SPORTSMAN 500 DRIVE SHAFT - A04CH50AO/AQ/AR/AS/AT/AV/AW/AX
2004 ATV SPORTSMAN 6X6 DRIVE SHAFT - A04CL50AA
2004 ATV A04CH59AF SPORTSMAN 600 FRONT DRIVE SHAFT - A04CH59AF/AH/AJ/AT/AV
2004 ATV A04CH59AK SPORTSMAN 600 FRONT DRIVE SHAFT - A04CH59AK/AL/AN/AQ/AW
2004 ATV A04CH68AC SPORTSMAN 700 FRONT DRIVE SHAFT - A04CH68AC/AF/AH/AJ/AT/AV
2004 ATV A04CH68AK SPORTSMAN 700 FRONT DRIVE SHAFT - A04CH68AK/AL/AN/AO
2004 ATV A04CH68AU/CU SPORTSMAN 700 FRONT DRIVE SHAFT - A04CH68AP/AQ/AU/CU
2004 ATV ATP 330 4X4 FRONT DRIVE SHAFT - A04JD32AA
2004 ATV A04JD50AA ATP 500 4X4 FRONT DRIVE SHAFT - A04JD50AA/AB/CA
2004 RGR RANGER 2X4,4X4,6X6 FRONT DRIVE SHAFT (4X4)(6X6) - A04RD50AA/AB/AC/A04RF50AA
2003 ATV SCRAMBLER 500 4X4 DRIVE SHAFT - A03BG50AA
2003 ATV MAGNUM 330 4X4 DRIVE SHAFT - A03CD32AA/AB/AC
2003 ATV SPORTSMAN 400 DRIVE SHAFT - A03CH42AA/AB/AC
2003 ATV SPORTSMAN 6X6 DRIVE SHAFT - A03CL50AA
2003 ATV SPORTSMAN 500 HO FRONT DRIVE SHAFT - A03CH50AA/AB/AC/AD/AE/AH
2003 ATV SPORTSMAN 600 FRONT DRIVE SHAFT - A03CH59AA/AF/AG
2003 ATV SPORTSMAN 700 FRONT DRIVE SHAFT - A03CH68AA/AC/AF/AH/AL
2002 ATV XPLORER 400 CV JOINT - NEAPCO - A02CG38CA
2002 ATV XPLORER 4X4 CV JOINT/NEAPCO - A02CG25CA
2002 ATV SCRAMBLER 400 4X4 DRIVE SHAFT - A02BG38CA
2002 ATV SCRAMBLER 500 4X4 DRIVE SHAFT - A02BG50AA/AC
2002 ATV SCRAMBLER 500 4X4 FREEDOM DRIVE SHAFT - A02BG50AA/AC
2002 ATV MAGNUM 500 2X4 HDS DRIVE SHAFT - A02CB50FC
2002 ATV MAGNUM 500 DRIVE SHAFT - A02CD50AA
2002 ATV MAGNUM 500 RMK DRIVE SHAFT - A02CD50AA
95scramblerruben1033
Sep 23, 2015 06:29 PM
jankerstien
Sep 21, 2015 03:09 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
cornermike
Sep 10, 2015 08:30 AM
