450r valve shim thickness
Old Jan 27, 2005 | 11:35 PM
drgnerth's Avatar
Default 450r valve shim thickness
What are the stock shim thickness for the intake and exhaust?
Old Jan 28, 2005 | 01:46 AM
TractorPacker's Avatar
Do you have a balloon?
I didn't know they were shimmed. I thought it had normal adjustable rockers???????? Or are you asking about your yamahahaha?
Old Jan 28, 2005 | 07:45 AM
dzzy's Avatar
On models with solid lifters and shim type adjustment, there really is no stock size. They're sized according to the measured valve clearance. The factory probably has a range of most commonly used shims, but that usually varies within several sizes. You have to remove the shim, the number stamped on it indicates the size. Alot of the time, the stamped number is rubbed off, then you have to measure them with a micrometer and go thicker or thinner depending on the measured clearance.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
