03 SP500HO, what does the foot brake do???
Old Jan 28, 2005 | 01:31 AM
FireCaptainSteve's Avatar
Default 03 SP500HO, what does the foot brake do???
Ive been told a few diferent things...I know the hand brake activates front and rear brakes. But what does the foot lever do ?
Old Jan 28, 2005 | 03:06 AM
jeffro206's Avatar
firecpt, its operates only the rear. its mainly there as a back up system to the hand brake, which is the primary braking, should it fail or get broken off.
polaris actually calls it an auxillary brake, and you will find, if not already, that it won't stop like the hand brake will. you're only braking with 1 set of pads and a small cylinder and trying to stop all that sp500. also, if you use it alot the cylinder will pull air into it causing you to have to bleed the system. this is because of the hose fitting that pushes into a grommet on the cylinder.
Old Jan 28, 2005 | 09:35 PM
My dealer said it increases engine braking???
Your saying it uses the bake brake.
Old Jan 28, 2005 | 09:50 PM
oldsmoboat's Avatar
Don't you need to depress it to get into Reverse and Park?
Old Jan 28, 2005 | 11:19 PM
jeffro206's Avatar
the engine brake is not controlled by the brake really. it is the way the clutches are designed. the front clutch has a one way bearing in it. and when you let off the throttle the engine slows down and in turn helps to slow the trans. the only reason it would seem to increase engine braking is that it would lock up the rear wheels sooner
as far as the reverse/park, that is not on an 03 sportsman 500.
Old Jan 28, 2005 | 11:44 PM
zerowick's Avatar
Two words: OWNER'S MANUAL. It's all in there guys. As a rule I wouldn't listen to the dealer, jeffro is a rare exception to that rule. You should tour the country jeffro and teach these dinks (dealers) a thing or two, it would really help the Polaris name. We need more knowledgeable dealers that care about customer satisfaction, not just the sale.
Old Jan 29, 2005 | 02:09 AM
jeffro206's Avatar
thanx zerowick. i just try to help out whenever i can. and you're right the owners manual has alot of info in it. just take a little time to read it thru.
Old Jan 29, 2005 | 06:39 AM
mtpockets's Avatar
FireCaptainSteve quote- "My dealer said it increases engine braking???"
your Dealer is as STUPID as they come! that takes the cake! just when i thought i've read it all!
Old Jan 29, 2005 | 10:17 AM
silverbullet2005's Avatar
where can I buy an actual model specific owners repair manual for my 2004 700EFI.
Old Jan 31, 2005 | 09:54 AM
The owners manual has very little info on the aux brake. I wanted to know if the dealer that told me it increases enging braking was right? now I know they are wrong Thanks guys.
