do i need to jet it
Old Jan 31, 2005 | 11:47 PM
ridemotox's Avatar
Default do i need to jet it
i put the fmf pipe on my blaster and never jetted it. will this cause problems . and what exactly is jetting it mean and do
Old Jan 31, 2005 | 11:53 PM
ZillaRider02's Avatar
Yes, you need to jet it........Both for better performance and longer engine life. With stock jetting and your FMF, the engine is running too lean. A larger main jet will increase fuel to the added air your engine is now moving. Running with the stock jetting can cause, a burnt piston, stuck/melted rings, blown head gasket, and not to mention a ton of money. Don't waste money on a "jet kit". Contact FMF and get a baseline jetting recomendation. Then, go your local Motorcycle/ATV shop to purchase the new jets (around $4 each). Consider installing a pro design filter setup to fix Yamaha's horrible airbox design and keep the engine clean. Hope this helps!
