350x axel carrier play
Old Sep 17, 2000 | 09:24 PM
honda350xman's Avatar
I have an 86 350x and where the axel goes through the swingarm, i think its called the axel carrier i dunno a whole lot about it but it has a little play, not a lot but a little bit. I dunno if it is normal or not i dont want to ruin my bearings or anything else, thanks for the help
~RENNIE~86 350X/85 250SX
Old Sep 18, 2000 | 04:55 PM
DunePilot858's Avatar
One of the reasons it could be loose is the bearings could be worn. As long as they turn freely and aren't causing you major concern I wouldn't worry about them.
Old Sep 18, 2000 | 05:43 PM
250R_Man's Avatar
I would worry, I've tossed chains before because I had bad bearings. If there is only a little play...like a small "click" when you move the bike side to side, then you can probably tighten the axel nut a little to eliminate the play. Once you reach this point, you should make plans to get new bearings. You can get them at a local bearing dealer or machine shop for $10 each. (Honda will charge you $25-30 for the same thing.) Get the number off the race of the bearing.
Depending on your riding, (rocky or rough terrain) and how often you ride they should last another 3 - 6 months without too much trouble. However, considering that the bearings will cost $20 plus seals, and if you throw a chain through your case ($600 min), I'd do the preventative maintaince.
85 ATC250R
86 ATC250R
97 900RR
bmxatv10
Oct 14, 2022 06:23 PM
shimanok2
Jan 29, 2016 07:37 PM
2many2ride
Sep 27, 2015 04:35 AM
scottdubya83
Aug 29, 2015 04:08 PM
