250ex, ticking away...
Old Feb 2, 2005 | 12:23 AM
jeffro206's Avatar
Default 250ex, ticking away...
hey, i got an 03 250ex in the shop today, havent done much work on this model. heres the problem. when you first start it it has a VERY loud ticking in the top end. quiets slightly after runs couple of minutes. already checked valve lash, ok. getting ready to start tearing down to find it. any guesses??
Old Feb 2, 2005 | 01:24 AM
jeffro206's Avatar
ok no answers. how about this - what size gun do i need to shoot it with?? lol maybe post that in hunting forum, hhmmm
Old Feb 2, 2005 | 08:40 PM
prieber14's Avatar
hmmm...ever think of lose bolts? simple check..but im sure thats not the problem. is there an aftermarket exhaust on there? it could be that the jetting isnt right but im sure u thought of that already too. i'll think on it
EDIT: maybe its low on oil? or hasnt had an oil change in awhile... i'll keep thinkin
Old Feb 2, 2005 | 09:28 PM
zoom545's Avatar
what octane fuel are u using. mine use to knock and make noises then i started usen betteer gass and im startin to put fuel booster or whatever to make the the gas better. thats what i would think.
Old Feb 2, 2005 | 10:00 PM
Gimpster's Avatar
Pull the rocker shaft and check for wear, also check the inside diameter of the rocker arms and see if they are ovaled.
When the valves are adjusted to spec and a rattle is still heard, these items are normally suspect. They are fine when opening the valve, but when worn will clatter at the pivot when no tention is on them
----- Gimpster -----
Old Feb 2, 2005 | 11:18 PM
jeffro206's Avatar
thanx for the input, but i found it. went out to the shop a little while ago after pm' ing prieber14 and tore it down. found the wrist pin and small end of rod are worn. i had told priber taht the oil was a little dirty, but full. well, my guess is that the oil was changed recently but way way overdue. most of the top end is worn. time for complete rebuild. just glad it ain't mine.
Old Feb 3, 2005 | 12:06 AM
tazlittleking's Avatar
Sounds like you may just need a valve adjustment. Nuts and bolts are always going to get loose.
Old Feb 3, 2005 | 06:02 PM
prieber14's Avatar
i never got a pm [img]i/expressions/face-icon-small-sad.gif[/img] lol
Old Feb 4, 2005 | 01:10 AM
jeffro206's Avatar
prieber14, sorry bout that. id did try to send one. d@&n computer.[img]i/expressions/face-icon-small-frown.gif[/img] think ill shoot this thing instead, been having a couple of problems lately.[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
Tomtom86
Aug 7, 2024 07:40 PM
Big bousse
Sep 26, 2015 10:42 AM
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 9, 2015 02:40 PM
MNatv89
Jul 7, 2015 11:36 AM
