Grizzly top speed?
Old Feb 3, 2005 | 03:33 AM
GrizzlyUpAndAdams's Avatar
Default Grizzly top speed?
I bought an 04 Grizzly new in June 2004. When it was new, it would go 66-67 mph according to the speedometer. After the first couple of hundred miles it would only go 62-63 mph according to the speedomter. (It now has over 2000 miles on it) I had the valves adjusted and it didn't make any difference. A friend of mine has an 05 Grizzly that is noticeably faster. Does anyone have any comments or suggestions on why the top end speed slowed down? I thought it would go faster after break-in. Thanks.
Old Feb 3, 2005 | 03:55 AM
Madwolverine's Avatar
Could the belt be slightly slipping?
I'm sure you've checked these but just in case:
-is the air filter clean?
-have you cleaned out the spark arrestor?
-air pressure in your tires (low pressure can slow you down quite a bit)
-are you still running the stock tires? Larger tires will change your speedometer and lug you down some
Old Feb 3, 2005 | 03:56 AM
Oh and what about your carb(s)?
Is it possible that you've had some trashy gas that might have partially clogged the carbs?
Old Feb 3, 2005 | 09:45 AM
Sluggo312's Avatar
hey, that's a good point about the carb. I've been careful to only use quality gas in my grizz but should I, on occasion, use one of those fuel treatments for cleaning carbs?
Old Feb 3, 2005 | 09:52 AM
renegade888's Avatar
We just had a customer complaining the same way. 1st he had a lower top speed than you are having. We immediately adjusted his float as they are usually not adjusted from the factory. That gave him an increase of about 10 mph.
Old Feb 3, 2005 | 09:59 PM
I will try those suggestions (cleaned spark arrester and have about 6psi in each tire). Thanks and if anyone else has a suggestion I would appreciate it.
Old Feb 20, 2005 | 08:33 AM
Starky's Avatar
I had the same thing with my 04 Griz. After break in I could get it up to 67 to 69. Now I think 65 is it's top speed. I've had the vales checked too and they are fine.
I just bought a 05 but haven't had a chance to ride it yet. I'm looking forward to doing some comparing of the 2.
Old Feb 20, 2005 | 01:15 PM
mich660griz's Avatar
cleaning the carbs out, and adjusting the float are good places to start.
the real reason why it is not hitting the speeds that it used to is becouse of the belt though. the belt( witch is the best in the industry) does and will strech slightly at about 1000 miles. this slows you down up to 10 mph. the belt is expencive, but needs to be replaced. all who have done so, have gotten back there top end. with 2000 miles on it, i can guarentee your belt is streched out. so, clean up the clutch, and slap in a new one,and you'll see a differance.
Pehter
Oct 3, 2024 11:00 PM
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
ReconBayou
Sep 23, 2015 02:41 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
