SCRAMBLER HELP
Old Feb 3, 2005 | 09:19 PM
BIGMANDSM's Avatar
Default SCRAMBLER HELP
I HAVE A 2001 SCRAMBLER 400 4X2 AND SOME HEAVY MODS WELL THE PROBLEM IS THIS IT SOUNDS LIKE THE CHAIN IS SLIPPING WHEN I GAS IT BUT ITS NOT THE REAR CHAIN(OPPS CAPS) took off the gear case and everything looked fine but the chain inside seemed a little strecthed is this very common problem should i replace the chain and gears? or is there something i am missing?
Old Feb 4, 2005 | 08:55 PM
1fastpolaris's Avatar
They do tend to stretch. It might be a good idea to change out the chain. You looked at the rear sprocket and made sure the teeth are not rounded of or chipped off?
Old Feb 4, 2005 | 09:08 PM
ftwflh's Avatar
Any time you take a gearcase apart it is a good idea to change out the chain to be on the safe side.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
