What's the rear rim/paddle size for Yamoto 150?
I have been looking for some paddle tires as well. Make Sure when buying them the rims are 4bolts with a 110 mm bolt circle.(4/110)
I might get a slightly bigger tire with same bolt pattern
There are some paddle tires on there that will make a perfect fit on the Yamoto 150.
If you havent done so already, you should replace the air box with a K&N R-1100 Filter.
You will need this so you dont kill your engine in sand.
The tires are $200(with rims) and the K&N is about $40(Must buy precharer wrap 22-8048pk)
I also have a site for a new exhaust from fmf if you want one.
http://www.rageperformance.com/atvtires.asp#11
This Site is for paddle tires^^^^
Which ones will fit? These?
18x9.5-8 5-paddle - $199.95 set
4/110bp - Bom 90cc, Pol 90cc, Eton 90cc
Yes, I want to get the K&N filter too for my Yamoto. What's the best way to access the airbox on these things anyway? Is it under the seat or the tank? Don't you need to do some kind of retro for the intake to get the K&N on there? Thanks.
How much is the fmf pipe for the Yamoto 150?
Yes those are the correct tires.
The Air Box is under the seat . I have not replaced it yet( because of the winter season it was cold) but by looking at it shouldnt be to hard. you will need also
a piece of pvc pipe that is 1.5 inches in diameter to connect the carb to the air filter.
As for the Fmf Pipe it is $150 shipped ups 2nd day air.
https://www.fmfracing.com/products/c...&ItemID=020302 <<< URL for pipe
http://www.ajusa.com/cgi-bin/knfilte...b784ebec200630 <<< URL for K&N Filter
http://www.ajusa.com/cgi-bin/knfilte...b784ebec200630 <<< URL For K&N PRECHARDE WRAP
1986Vmax540
Jul 9, 2021 09:53 PM
