which jet?
Old Feb 4, 2005 | 11:33 PM
crazyhead's Avatar
Default which jet?
Have an 03 pred with full yosi exhaust, cdi and new mod air intake which extends from the carb via a pipe 14in long going into the opened airbox, which nows has k&n with outerwear. Any help would be greatly appreciated as right now it seems to bog down and when I pin it, it sumps but recovers. Running a 180. Thanks in advance
Old Feb 4, 2005 | 11:45 PM
RAJ's Avatar
RAJ
Default which jet?
Do you have the Rath K&N Intake? I running a 172.5, with my set up. Do a plug check and see what it looks like, I think you might be rich.
Old Feb 4, 2005 | 11:52 PM
crazyhead's Avatar
Default which jet?
Not a Rath but a pipe made for me, bent so K&N sits just inside opened airbox. Tried clamp on but would fall off at dunes sometimes, not willing to take risk so this setup will not come off.
Old Feb 5, 2005 | 12:00 AM
RAJ's Avatar
RAJ
Default which jet?
I also have the bottom of my air box, It works good for a splash guard.....I sold my Rath Intake...i'm going with the Twin Air. I would do a plug check and see what it looks like.
Old Feb 5, 2005 | 12:03 AM
crazyhead's Avatar
Default which jet?
Be careful as sometimes they fall off and if you are around sand then you have a problem. This is why I went to a rubber piece at connects to the carb and the pipe to the K&N. Trying to dial it in but having a hard time.
