400ex steering stem
Old Feb 6, 2005 | 06:26 PM
TractorPacker's Avatar
Do you have a balloon?
Default 400ex steering stem
Does anyone know of a good option for the upper bushing. I have to pull the hard green bushing out and grease it alot. I see a bearing can not go on it, but someone has had to made a better option. If you can help, LMK.
Old Sep 30, 2005 | 11:44 PM
mxjunky's Avatar
i had the exact same problem. take the bushing ojut and clean it, the stem and bushing clamps. then take the outer clamp and drill a hole to tap to 1/4-28 thread in it above the center of the clamp. then drill a hole in the bushing that will line up with that hole (that bushing is hard to drill through so use a drill press and start with a small bit like1/8" then work up to about 1/4 - 5/16"). somehow mark the bushing to the clamp where they line up. install a grease zerk in the clamp, reassemble, grease and you're ready to go. just maintain it like any other greaseable part and notice how smooth and easy it is!
Sep 30, 2015 01:37 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
