Will it fit?
Old Feb 9, 2005 | 02:37 PM
johnnymac's Avatar
Default Will it fit?
I've got an 03 F-150 extended cab - shortbed. Will a 2005 Polaris SP400 fit in the bed with the tailgate up ? Thanks
Old Feb 9, 2005 | 03:09 PM
jimmypsp700's Avatar
An 02 sp700 will fit in a Z71.
You could always leave the gate down and/ or get one of those nets or flip back gates.
Also you can use plastic ramps up front to lift the quad for more room (got that from Jeff).
Old Feb 9, 2005 | 03:58 PM
sdbowhunter's Avatar
I have a 1997 F-150 4x4 extended cab shortbox and my 05 SP700efi will fit in the back. I have a bedliner in mine too, there isn't much room on the sides of the wheels when you get it in. If it was any bigger it wouldn't fit in mine width wise.
Old Feb 9, 2005 | 05:16 PM
I8ACAT's Avatar
I also have a '97 F-150 and my '05 700 will fit. You may try to back the quad in the truck. For some reason, it makes a difference with my truck. Hope this helps.
Old Feb 9, 2005 | 08:09 PM
DirtFarmer's Avatar
I could not get the tailgate up on her 99 f 150 stepside short bed with a sp600 in it. The front of the 4 wheeler was to close to the window since it bubbles out, back over the bed. It might fit backwards or with some blocks under the front tires I didn't have time to try. Good Luck , Jeff
Old Feb 9, 2005 | 09:35 PM
silverbullet2005's Avatar
sorry I don't own a ford but I wanted to let everyone know that my 04 700EFI will fit in the back of a 2004 Dodge ram 1500 shortbed but only with the tailgate down.
