brute force queastion
Old Feb 9, 2005 | 08:10 PM
tommyboy84's Avatar
Default brute force queastion
I want to know how the brute 750 with a dyna in it stacks up against a stock V or a stock yfz in a strait line with no turns or bumps. If any one knows pleas relpy, thaks
Old Feb 10, 2005 | 01:19 AM
ridinsmooth's Avatar
1st . yfz
2nd would be tied between the v and brute i could give you more but you did tell if it was the 650 or the 750 i hope this helped
Old Feb 10, 2005 | 01:43 AM
rivermud's Avatar
Never rode a YFZ but a brute with dyna properly jetted should beat a STOCK V in a 300' race. The brute will need the stock wheels and tires, run in 4wd, and if its a short race run in low range. Then you can use every advantage your quad has. As far as a long run I have know Idea.
Old Feb 10, 2005 | 05:58 PM
lewichris's Avatar
Originally posted by: ridinsmooth
1st . yfz
I dont know man, Check out the thread and the video. you may be wrong about the yfz
race
Old Feb 10, 2005 | 10:57 PM
OGGYDOGGY's Avatar
A good running Bf 750 will beat a stock yfz in a stright line, this has been proven by ZQUAD check out his vid.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
