barnett clutch question
Old Feb 12, 2005 | 07:21 PM
thebigshow's Avatar
Default barnett clutch question
The last time i had my clutch changed i had my local dealer do it..he was "SUPOSED" to install the 9 disk barnett clutch, but when i tore it apart today i only counted 8.... i ordered a 9 disk clutch to replace it and when i put the 9 disks in it just didnt look right, it looked like the basket wasnt big enuff to hold all the plates...i was just wanting to make sure and to see if can run a 9 disk set-up with the stock baskett..thanks Rocky
Old Feb 12, 2005 | 07:27 PM
2BIG2BFAST's Avatar
stock basketheld all mine you might want to get the rw60% springs. changed mine in december and used springs that came with it now imm gonna have to do it again
Old Feb 12, 2005 | 08:19 PM
JDsBusa's Avatar
I was thinking of isntalling the 60%rwr springs back in mine after I did the 9disk. I guess it worked ok in yours?
Justin
Old Feb 12, 2005 | 10:05 PM
Eaglecollector's Avatar
Barnet 9 disk fit fine it the stock basket. Thats what I run along with the 60% springs and the magura hydralic clutch. Very sweet setup indeed. I can pull the clutch in with 1 finger[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 12, 2005 | 11:33 PM
thebigshow's Avatar
i think that magura clutch set-up will be my next purchase....im going to tare it back down tomorrow, it just looked like there wasnt enuff room for two more plates when i first looked at it.....did u offset the last plate, or does it matter?
Old Feb 13, 2005 | 01:04 AM
The kit that I got had the one diff plate to use in the offset position so I went ahead and used it that way. I know scooby told me once that he doesn't offset his. It really doesn't matter as long as you don't run them past the wear limit. Thats really all the offset is for. So that you can't run them past a certain point.
Old Feb 13, 2005 | 02:15 AM
busmechanic's Avatar
9 disc in mine too. I did the same as eagle. put the odd plate in last offset groove. fit fine.
Old Feb 13, 2005 | 07:25 PM
CountryJoeGlass's Avatar
We just finished installing the barnet 9 disk clutch on my brother DS today. It fit fine in the stock basket, no problems yet. should be starting it up in the next 15 mins.
Old Feb 13, 2005 | 07:31 PM
A little hard to find nuetral at first. But that goes away as they settle in.
Old Feb 13, 2005 | 07:36 PM
Eagle very true, it was that way when I installed mine. Thanks for bringing that up.
