1986 Honda TRX 350 start cold electrical problem
Old Feb 16, 2005 | 11:57 AM
waybel350's Avatar
Default 1986 Honda TRX 350 start cold electrical problem
My honda 350 has a weird problem.It starts with no problem when it is hot with electric start but try to start it up when cold and no go just floods.The electric starter cranks over till battery dies and no go.Asked a local Honda mechanic and he said to try the kickstarter instead of the electric start when cold and sure enough it started.He said something about coil or something and not getting enough spark on cold start.Anyone have any idea what this could be or what electrical tests to try.Thanks
Old Feb 16, 2005 | 01:32 PM
LittleBill's Avatar
alli can think of is the starter is taking so much power to turn the bike over, its not leaving enough voltage or amperage for the coil to fire, thats prolly it works when u kick start, trying connecting it to a another battery when starting cold and see if it will fix it, so use 2 battery's or jump start it off another car or quad
Old Feb 17, 2005 | 12:17 PM
waybel350's Avatar
Thanks for the reply but i tried that and no go/It turns over superfast but does the same thing.Last night i tried taking the plug out to check the difference in spark from turning over with the electric start or the kickstart and i couldn't really see any difference.Both had equal spark
Old Feb 21, 2005 | 01:26 PM
oneshot7525's Avatar
we have the same problem, Whenever it is below zero the oil is so thick you cant start it. We put a heater on it and 10 minutes later it fires right up
MikeyBoyesq
Nov 27, 2020 02:44 PM
TJM
Jun 11, 2015 01:28 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
