I am thinking of taking off my clutch side cover and-
checking everything out inside, measuring my plates and the fiber discs to see if i need any new ones,right now i have the motor in the house i am rebuilding it and i have read lots of posts about guys rubbing the steel plates on cement to roughen them up, here is my question, it has been sitting since november 19th in the house with no oil in the bottom of the motor-I covered everything in a light film before i had surgery will the clutch fiber discs be ok this long and secondly how hard is it to put the seal in for the clutch lever? mine is leaking a little, the top seal under the leaver, i am putting in a 11.2:1 mrhp piston with a endcap and ported intake should i go with heavier springs? 40% 60% and how much are they any advice would be greatly appreciated thanks fellas
Most people run the 60%. With your current mods you would probably be fine with the 40% but if you happen to add more mods down the road, say a carb, then you will probably have to swap out later for the 60%. I would say just do the 60% now and forget about it.
I ordered directly from Ron Woods www.rotax.net $25-$30
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chuck1177
Jun 7, 2015 10:18 AM
