Broke shifter box
It's what I call the "pre" transmission gear case cover. Has several shift gears,a detent lever that are packed with grease from the factory.These gears turn the internal shift drum and shift forks.Over time water entry can wash the grease away,gears can rust up and make shifting hard.Item #3 on the parts breakdown.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Here's some pics from someone on the other forum that that repaired his gear box.Hard to Shift 700 Sportsman 2004 - Polaris ATV Forum OR possibly you're talking about the gear position switch that's broken. Item #69 on the same parts breaks down list..
NO this is not an assy. The cover,and parts inside are sold separately. Look at the parts break down list.Plus look close at the pics on the post I linked to.You should be able to determine what parts you may need once you clean this area. May not need anything but cleaning and greasing.
Steeldon
09-09-2015 09:38 AM
