predator steering post problems??
Old Feb 20, 2005 | 09:26 PM
rohrerss's Avatar
Default predator steering post problems??
anybody have problems with there steering post??? i had my bike flip over going up a very steep hill, the bars bent slightly, but the steering post bent along with the bracket/frame mount?? i took the post out and it seems very cheap as far as quality??? any aftermarket posts made??
Old Feb 20, 2005 | 09:32 PM
RAJ's Avatar
RAJ
Here are a few that makes them.....HPD Rath Racing
Old Feb 20, 2005 | 10:41 PM
RAJ's Avatar
RAJ
I also found that Rocky Mountain has them also.
Old Feb 21, 2005 | 09:58 PM
Bradracer18's Avatar
HPD is your best bet on this one.........they are strong, and a nice quality part, and the cheapest too!!!
Old Feb 22, 2005 | 09:20 PM
rohrerss's Avatar
I straighted the steering post and re-installed it, my question because i cant remember should the steering post have any play in it??? it has a rubber bushing with a clamp(half moon style with two bolts to mount it to the bracket. the post is straight but i have very slight movement from front to back?? anyone with any thoughts??
Old Feb 22, 2005 | 09:46 PM
there is a bushing that goes in there..........might need a new one.......it not, then you probably don't have it strait, or you have wallered out that clamp.
Old Feb 22, 2005 | 09:48 PM
rohrerss's Avatar
the clamp seems ok and the post seems straight?? so you dont think there should be any play at all??
Old Feb 22, 2005 | 10:43 PM
There shouldn't be much play......I don't know how to explain it......mine has a little(very minimal).......like maybe moving 1/32 or 1/16 of an inch..........I'd say that is ok, but not any more. Did you see if your bushing(I think they are plastic) is ok??
Old Feb 23, 2005 | 11:40 AM
twoie's Avatar
I did the same thing to my 05 pred. You need to make sure that the large metal gusset is not bent. Where the upper steering stem bolts on bends very easily. When I replaced my steering stem with the HPD I had to straighten it out and weld in some supports. Hope this helps.
Old Feb 23, 2005 | 06:57 PM
rohrerss's Avatar
thanks for the infro, i called darryl at hpd. he was a big help.
