Question on brakes
Old Feb 22, 2005 | 12:21 AM
new2atv's Avatar
Default Question on brakes
I was looking at my front brake pads today on my '01 Xplorer 400 and I was wondering if I should change them. They are the same pads that were on it when I purchased the ATV about a year ago so I don't know when they were last changed. The only way I had to measure the pad thickness was with a tape measure and they were 3/16 of an inch thick. When is a good thickness to consider changing them? I could probably still get some miles out of them but when I do change them, what's a good pad to use?
Thanks in advance.
Old Feb 22, 2005 | 12:41 AM
jeffro206's Avatar
if the pad itself, not including backing plate is that thick then leave'em on. you've got a ways to go before they need changed. make sure all the pads are about the same.
Old Feb 22, 2005 | 10:16 AM
new2atv's Avatar
I only measured the pad so they must obviously still be in pretty good shape then. I'll need to check the back pads though. Thanks for your response.
Old Feb 26, 2005 | 11:19 PM
brainpause's Avatar
A good rule of thumb, and easier than a tape measure, is the pad should be at least the thickness of a dime.
Larry
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Oct 16, 2019 12:11 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
DeFox500
Jul 26, 2015 06:32 PM
